Hi everybody,
I have a problem! I will tell at first, the process what i'm doing. I have already a dvd-r. Let's say MIB2. So everything on the disc works and is already fixed. But i want to add Dutch subs(i'm from the Netherlands) Now i use DVD decrypter. I'm ripping the video file and the audio file. Then i use DVD Maestro. I delete the menu. I put the m2v file, the ac3 file and the dutch subs together. I import the chapterlist. Then i compile everything.
I use Record Now Max 4.50. I choose for the Data option and i add the Video_ts and the Audio_ts. When i go to "tools" and then "options" and look at "Data Disc" the option "recognize theVideo_ts and Audio_ts folders per the dvd specification" is marked. Then i start record and everything goes fine. I can play it on my Sony 725D and Lenco 02.
Now a little change. I want a menu on my movie. I use IFO Updater for this. I have now the new folder with the Dutch subs and a folder with all the original files. From the folder with the Dutch subs, i keep the Vob files where the movie is in and i put the VTS_01_0.IFO file away to a different place. Then i add all the files(except the Vob files with the movie) in the new folder. Then i combine the VTS_01_0.IFO files.
Now i go to Record Now Max again and i add the Video_TS and the Audio_TS again. Now, when i try to burn, i got an Terminated error and it won't start. I go to "options" and uncheck the option "recognize theVideo_ts and Audio_ts folders per the dvd specification"
Now i can burn it.
But the result: On the Lenco it works great but on the Sony 725D i see for 14 seconds the intro of Universal. But that's it and it stops. It won't go to the menu.
Can somebody please help me with this problem? Or does somebody know a way to burn, so that i can play my dvdr's on my Sony.
Blackadder
