  1. Definitely newbie here No matter what program I've downloaded to convert formats, it gives me this message: The MSACM32.DLL file is linked to missing export NTDLL.DLL:RtlOpenCurrentUser. Is this something I need to find? TIA!
  2. Oh yeah, I tried to download the Nimo codec pack from the tools section and the page comes up not viewable due to errors?
    PA, USA
    from www.google.com
    "Something has installed a newer version of msacm32.dll on your PC in the windows\system folder"
  4. Thanks, but it looks like those instructions are for Win95. I've got ME.......I am so stuck! Ok, I found DLL World and downloaded the file. Is there somewhere specific I should be putting it or will the program find it on it's own. TA!
    PA, USA
    your still going to have msacm32.dll in your system folder.. if your on ME. you should be able to re-extract that file from your CABS
    start->run
    type in MSCONFIG
    hit the "extract file" button at the bottom
  6. You're the best It works now! THANKS!
