I am trying to backup my video tapes using and Xtasy Xtream video card. I keep getting the center of the viewing screen with a white band which I found out to be the macrovision. How can I disable the macrovision on the Xtasy card.
I get this band with Virtual dub, Ulead DVD, and Win VCR.
Any help will be welcomed.
You need to update the WDM capture driver, find version 1.8 and install it. This should eliminate the white band.
Thank you for your response.
However, I have not been able to find verison 1.8. Do you know where I can find it?
Macrovision like NONE OTHER
By blacksheepdownunder in forum Capturing and VCRReplies: 17Last Post: 22nd Jul 2010, 04:16 -
Is it Old or is it Macrovision?
By Tiggerpaws in forum RestorationReplies: 4Last Post: 7th Aug 2009, 16:31 -
Macrovision
By adamrose in forum Newbie / General discussionsReplies: 15Last Post: 22nd May 2008, 20:41 -
Xtream Media Server
By angiesdaddy78 in forum Media Center PC / MediaCentersReplies: 0Last Post: 22nd Apr 2008, 01:11 -
Macrovision Help!
By dollydoodledumplin in forum DVD & Blu-ray RecordersReplies: 11Last Post: 24th Nov 2007, 10:37
