Ok this is going to sound really Newbie but how important is KBS in DIVX Capturing. My Caps are coming off VHS tapes each, they are cartoons and each one is around 22 Minutes long.. oh and 640 x 480 Res..
I'd like to get two of these burnt to a CDR which I will work with later on.. Right now I captured one episode at 4000kbs the file was around 630 Megs when I was done. I then tried one at 2000 KBS the final size was around 425 Megs when I was done.. I suppose I will have to go a bit Smaller to get the size around 350 Maybe 1500KBS.. I knwo there is a calculator I can use.. Maybe I'll try and work with that..
However how much of a loss will I get in quality going from 4000 KBS to 1500 KBS I suppose alot.. so maybe its wiser to just burn each episode to a single CDR.. or si the difference so little I will barely notice..
Any Advice would be cool..
Results 1 to 1 of 1
New Receiver & DIVX
By denzlite in forum Newbie / General discussionsReplies: 6Last Post: 17th Jun 2009, 06:35 -
Need a program to combine & cut divx, mpg & wmv
By sync in forum EditingReplies: 3Last Post: 14th Nov 2007, 08:02 -
Problem Divx's & Xvids
By ramses505 in forum Video ConversionReplies: 3Last Post: 8th Oct 2007, 10:39 -
ffdshow -XviD & DivX same?
By tigerb in forum Newbie / General discussionsReplies: 3Last Post: 14th May 2007, 03:16
