Does anyone know of any issues with Firewire Cards and XP/Movie Maker?
I don't always get a signal from my Canopus, but WMM is detecting it. The resulting file that is created from this is unplayable saying that the Codec is missing or the file is corrupt.
Then later, as if by magic, all is well again.
Anyone got any ideas?
Cole
the only thing i can think of is that you might be using a texas instruments firewire card, in which case there is a severe compatibility issue...maybe you'll want to check it out...
good luck! -
Alenhard,
Thanks for the reply.
I have found out what the problem is, it was Windows Movie Maker that was at fault. I tried a copy of Edit Studio 2 and it now works every time.
It takes ages to sort some of these things out1
Cole
Firewire device to computer with no Firewire
By dbuser2 in forum ComputerReplies: 11Last Post: 24th Sep 2010, 21:32 -
Building a new PC - This is annoying
By Des in forum ComputerReplies: 5Last Post: 9th Jul 2010, 17:54 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 12:19 -
The Most annoying Celebrity
By Cirone in forum Off topicReplies: 22Last Post: 4th Feb 2008, 13:32 -
Annoying error i keep getting...
By SE14man in forum Newbie / General discussionsReplies: 5Last Post: 1st Jan 2008, 04:33
