I just down loaded my first movie to my hard drive. Now I tried to play it on my windows player and the sceen is just black, but my movie counter show that the movie is playing. What do I need to do so I can see/hear the movie playing? Thanks!
Results 1 to 12 of 12
You need the correct codec installed to play the movie correctly. Try installing the nimo codec pack. This has most of the codecs you will ever need.
I down loaded the nimo pack. Now what do i need to do in order to play my newly downloaded movie on my comp?
You don't have to do anything.
You just leave the Codec Pack in any folder and the player will find it."Today is only yesterdays tomorrow" -
The player is playing the movie but no picture or sound is present. What next?
Im assuming by that, you mean you downloaded, and installed it right?Originally Posted by jj2tuff
you unzipped it??Originally Posted by jj2tuff
What kind of file is it?
(try opening it in Virtualdub and go to File> File information)"Today is only yesterdays tomorrow" -
Ok I opened up virtual dub, went to FILE but the FILE INFORMATION tab is grey not allowing me to press the button. Now what?
The nimo codec pack... is a zipped fileOriginally Posted by wee haggis
so of course you want to unzip it
then you will have an EXE file
probably called nimo.exe or something to that effect
double click that
and install it
then reboot
and try watching your movies again -
I rebooted and opened up my media player and guess what happend? Thats right NOTHING....Grrrrr what is the proper way to do this?
ahh...I was'nt paying attention.
I thought you were referring to a video zip file...mmm!!
Confusion is my middle name.
Do you have other movies or video files...?
Try them to see if its an issue with that particular file or all of them.
When you went into Virtualdub,did you...
File > Open > Movie.avi ? first before attempting to read Information?"Today is only yesterdays tomorrow"
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 08:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 13:13 -
Should I Get An HD Camcorder? (Newbie)
By davebo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 18Last Post: 21st Jan 2011, 04:48 -
Newbie needs help!!!!!! DVD to xbox 360 streaming
By JohnS719 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2010, 08:38 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 09:43
