What program do I use to view VCD's on a Mac?
Quicktime will also play them
- Elreeko
"I have not failed. I have simply discovered what does not work." - Thomas Edison -
I like VLC because it's free and it's, if not better, just as good.
elreeko,
Regarding QT playing VCD... I don't know about it, because it doesn't play VCD for me. How did you do it? I am just curious. -
I'll try to set this straight...Quicktime 5 will play VCD's in OS 8/9 and OSX up to and including 10.1.5
Quicktime 6 does not play VCD's and Quicktime 5 doesn't play in Jaguar 10.2 and newer. It isn't yet known if this is a bug or if it is a feature. It does seem that it would have been fixed in either 6.01 or 6.02 if it was a bug.
Good point from someone that you can use Quicktime 5 in Classis within Jaguar as this would be the free way to play VCD's. VLC is a nice app but some disks play and some don't. In time it will be better. MacVCD-X is a great app but isn't free. -
It has been my experience that quicktime (OS 9) will play vcds, but you cannot simply double click on the .dat file. In order to play them you have to double click on the .mov file that is found in the main folder. I have only been in the situation a couple of times where I have needed to play a vcd on my mac (instead of my console dvd player) and this way has always worked.
I haven't been able to test this in OS X as I have only ever done this with my laptop connected to a tv (so that I can see my desktop on screen) and unfortunately I don't have OS X loaded on it.
I also haven't tried this since quicktime 6 came out.
- Elreeko
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 06:04 -
Capturing VHS to Mac via Panasonic AG-1980 and ATI 650 USB Mac
By Stu187 in forum Capturing and VCRReplies: 3Last Post: 15th Aug 2010, 06:45 -
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 06:18 -
im new to mac... is there a mac program that does what tmpgenc dvd author 4
By ochsfamily in forum MacReplies: 0Last Post: 12th Dec 2009, 23:13
