I just bought this unit and it installed without any glitch. The only problem is that whenever i try capturing analogue, it will capture the first time, but then after i stop the capturing and then try and capture another segment with the same setting (analogue capture), it's like the capture card will turn off itself and won't produce anything on the screen even preview. It will just go back and capture again if i shut down the pc and then restart it again. Mind you, it has to be a full shut down before restarting again or the capture card will not turn itself on again. I am using it with an ASUS NForce2 Mobo. I have set the pin on the capture card so that it could be controlled using the windows based application that came with it. I don't know what is causing this problem. And can anyone tell me if this card will work with the Windows Movie Maker doing analogue capture? Thanks and any input will be very much appreciated.
