If i were to convert a movie to MPEG1, 352x240, and convert the same movie to MPEG2, 352x240 (non-standard i know) ..
would the MPEG2 file have better quality?
and if so would the file size be that much of a difference?
Results 1 to 15 of 15
If bit rate is low.peg2 is worst.
If bit rate is high enough, 1700 and up, mpeg2 is better. -
when i tried a mpeg2 file i could only get around 35 min. per 700 mb blank disc. so file is considerably larger due to less compression.
It all depends on what bitrate you are using also.
standard bitrate for vcd is 1150, svcd is around 2500
higher bitrate = higher quality -
Yes, that's normal.
mpeg2/SVCD is about 40 minutes per CD.
mpeg1/VCD is about 80 minutes per CD. -
It depends on the quality of the source whether its worth putting it on svcd mpeg2 or not. If source is only poor to average eg VHS, there will be no advantage to putting it onto SVCD, as you cannot improve on the source quality. If the source is good eg DVD or cable capture then SVCD can look considerably better than VCD.
Originally Posted by SingSing
So it doesnt matter, size wise, if i encoded the SVCD at 352x240 or 480x480? It would result in the same file size??
no. the higher the resolution, the larger the file. i personally use mpeg1 at 720x480 with a bitrate of 2000kbps. 45 minutes per disc.
what johneboy is talking about are compliant vcd and svcd files. -
just to clarify...
lets say i want to take a 10 min clip from a DVD.
I encode the clip as
MPEG1 @ 352x240 3000kbps
and then encode the same clip, from the DVD to
MPEG2 @ 352x240 3000kbps
which will look better?
which will be smaller?
both are obviously non-standard.
I assume i would get more playing time with the lower resolution on the MPEG2, as apposed to a MPEG2 at the standard 480x480, but how much (roughly of course) -
No, framesize doesn't have anything to do with the total filesize per se.
The only thing that affects the total file size is the LENGTH of the clip and the average bitrate.
If you use CQ encoding, however, you can't set the average bitrate so in such a case, a larger framesize will lead to larger files (as the average bitrate will end up being higher).
Regards.Michael Tam
w: Morsels of Evidence -
They will both be the same size as the bitrate is the same and presumably the length of the clip is the same.Originally Posted by johneboy
The quality will be pretty much equal. Per bitrate, MPEG-2 doesn't have much of a quality advantage (if any) over MPEG-1. What MPEG-2 can do is support interlaced video (but this wouldn't make a difference at your frame size). It may also depend on the individual encoder on whether it encodes MPEG-1 or 2 better.
Regards.Michael Tam
Sorry to butt in, but I have a question.
After reading this, I get the distinct impression that MPEG2 is used only for its interlacing capabilities. So, assuming I'm encoding progressive video anyways, would it make sense to use MPEG1 instead of MPEG2 on a SVCD?
Basically would MPEG1 at 480x480, 2000kbps+ look (noticeably) worse than MPEG2 at the same settings? -
And can someone explain to me why, after posting at 9:40 on the 20th, the thread didn't move up at all? And why vitualis was still listed as the last poster?
looks like its updating nowOriginally Posted by Mercury
thats a good question, and i was wondering the sameOriginally Posted by Mercury -
It probably won't look much worse for progressive video.Originally Posted by Mercury
However, SVCD doesn't support MPEG-1 video so unless you like making your SVCDs arbitrarily XSVCDs, you should stick to MPEG-2 for SVCD.
MPEG-2 also supports things like 3:2 pulldown flags which makes a difference for progressive film frame-rate video.
As for updating times, according the feedback forum (I think), there has been problems with php running on the new server or something... Crashes causes timing irregularities on the board.
Regards.Michael Tam
Avi to (MPEG1, MPEG2 PS)
By kilee in forum ffmpegX general discussionReplies: 7Last Post: 27th Dec 2010, 19:39 -
remuxing mpeg1 audio to mpeg2
By ChaosOrb in forum Newbie / General discussionsReplies: 3Last Post: 9th Sep 2009, 15:25 -
Question about which is more clear, mpeg1 or mpeg2?
By jimdagys in forum Newbie / General discussionsReplies: 12Last Post: 25th Sep 2008, 02:08 -
Burned an MPEG2, replicator says it's MPEG1 and unusable?
By First1 in forum Authoring (DVD)Replies: 4Last Post: 11th Nov 2007, 14:55 -
Mpeg Streamclip_DVD to Mpeg1 or Mpeg2
By edit204 in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2007, 11:58
