I'm a newbie to dvd burnig,and yes you guessed i ain't got a clue.Basically i have a load of mpeg files that i'd like to burn to dvd+rw
1.What program do i use to burn
2.which format should i convert to if any
i want to burn so that i can play on my stand alone dvd player.
Any help would be greatfully recieved
Since you are new, you should first read the Newbie Guides at left. They should answer your questions, for the most part.
Go to the DVD players database at left to see if your DVD player can play home spun DVDs. If it does, you will need an encoder, if the files you have are not DVD compatible. I prefer TMPGEnc Plus to do mine.
You load the MPEG files into TMPGEnc, encode them to DVD compatible MPEG files, then burn them with your favorite burn software, e.g. Nero, etc.
That is the basics of it. Happy authoring!Hello.
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
DVD > AVI or Mpeg fo re-edting then burning to DVD
By nutshellml in forum DVD RippingReplies: 7Last Post: 31st Mar 2008, 09:12 -
AVI to MPEG and burning DVDs
By mc-help in forum Authoring (DVD)Replies: 6Last Post: 6th Jan 2008, 13:23 -
AVI to MPEG conversion and DVD burning
By mc-help in forum Video ConversionReplies: 2Last Post: 5th Jan 2008, 16:08
