Simple question : Can you manually type in the point at which you want a chapter stop in Spruce-Up, or do you have to always drag that damn slider?
Cheers,
DJ
I have that exact question as well. I don't mind using the slider but I can't ever get it exactly where I want it. That kinda irritates me.
Can you manually type it in? No
Not going exactly where you want it? The problem is that a chapter point can only go at the start of a GOP (ie, an "I" frame). Most GOP's are 12 - 15 frames long. This gives you 3/8 to 1/2 of a second setting ability (meaning that you can only set a chapter point every 0.375 or 0.5 seconds). If you need a chapter set more accurately than this, then you are going to have to tell the encoder to insert "I" frames at the exact point where you want a chapter (consult your encoder manual to learn how this is done for your particular encoder).
So, "damn slider" it is. -
If you click on the slider, you can then position with the curser keys. It will get you to within 0.5 or sec or so of your target, albeit slowly.
just be happy you dont get a movie w/o any chapters
Originally Posted by dilligaf
Cheers
DJ
PAL to NTSC Chapter Points
By sambat in forum Authoring (DVD)Replies: 7Last Post: 3rd May 2009, 08:52 -
User-defined chapter points
By saber540ltd in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 26th Mar 2008, 18:38 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 10:39 -
new chapter points in PGCedit
By kshavo in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2007, 13:51 -
Moving Chapter Points?
By netmask56 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2007, 20:33
