Hi.
I've got this huge problem and i've tried everything.
I've read the HOW TO's and searched for an answer here.
Problem:
I have downloaded CUE/bin files and want to burn them on a DVD+RW. NERO just spits the disc out, asking for a CD-RW instead.
Is there any program available that can do this?
you just have to extract the data in the bin file first and then go from there (basicly either burn a data dvd or re-author to dvd (and prob re-encode) .. info on this to the left ..
Ok. Thanks. Just one question. What program do i use to extract the Bin-file? Can't find a "How to".
You'll use either vcd gear as it will show you on the guide page or IsoBuster
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 21:33 -
i have a 4 year old dvd burner that seams to burn a full dvd but the movie
By dr.bling in forum DVD & Blu-ray WritersReplies: 3Last Post: 16th Aug 2009, 23:20 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 12:58 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
