  1. I find that I can burn to a CD-RW when it is new out of the case, but once it is used I can not get NERO to write to the disk. I have reformatted the disk with InCD but still unable to reuse the CD. Is it possible to reuse a CD-RW to make a VCD like you do when you make a data disk. Is there something I'm doing wrong, or is it a one shot write to the disk when making a VCD.
  2. Have you tried using the "Erase ReWriteable" command under the Recorder menu yet?
  3. thanks for the advise, that worked. now I can reuse the 10 disks I have tested different formats with.
