I was capturing a non-multisegment file when Vdub inexplicably crashed. After rebooting I attempted to open the 3.3gb file in Vdub while reconstructing the missing index block but it stalled at about the 75% complete mark.
This file can not be opened by Vdub, Premier, WMP, BSPlayer, Zoom. The only way I can view any of the clip is by using AVIPeview. Even still, it allows me to view again, only about 75% of the clip.
I viewed the AVI header using AVIEdit and it was missing the "frames" and "length" values. Also note that this file can not be copied and pasted within the windows enviroment as I noted while trying to make an expenable copie for repair test purposes.
Capture was done using HUFFyuv. Any and all information you could give in regards to recovery would be greatly appreciated as I will not get another chance to capture this scene in the forseeable future.
Thanks,
Golem
I do not know of any tool. If I still want to use the current corrupt file, I might open this file in a Hex Editor and try to fill in the "frames", "size" manually as required by the format.
The best option however is to recapture again.
How to recover large AVI file after formatting digital camera memory card?
By 2Bdecided in forum RestorationReplies: 2Last Post: 5th Aug 2011, 12:01 -
Vdub: Screen Capture
By dylz in forum Capturing and VCRReplies: 6Last Post: 12th Jan 2011, 16:24 -
UBuntu, workpane crashed, mouse active ... keyboard recover?
By edDV in forum LinuxReplies: 3Last Post: 22nd Oct 2010, 03:22 -
split fields in vdub capture
By greenbag in forum Capturing and VCRReplies: 0Last Post: 18th Jan 2009, 22:50 -
Vdub not responding. Any way to recover the captured file?
By tristinho in forum Capturing and VCRReplies: 3Last Post: 5th Feb 2008, 11:06
