I need to find out how to take audio from a concert DVD (AC3 file) and convert it to a wav file and also put the next song points in it. Does anyone know of a guide on this and if not maybe the programs you would need to do this? I want to make a music CD of some of my live concert DVD's that I have.
One way would be to rip the DVD to your harddrive using SmartRipper (or another rip program) then use DVD2AVI to decode the selected audio track. You'd be left with a big .wav file then. Of course it would be a .wav file of the whole DVD but you could always split it using Goldwave, Cool Edit or some other audio editing program.
Check out...
http://www.vcdhelp.com/sefy/
Just go through the first two steps, ripping and frameserving.
I think there's a program called VOB2AUDIO that extracts a .wav file from the ripped DVD .vobs on your hard drive. That might be a better approach for your needs. I suggest doing a search in the forums for VOB2AUDIO.
GGS.
PS. try this guide. It uses VOB2AUDIO.
http://www.vcdhelp.com/pinoy2201sdvdrippinguide.htmEat! Drink! Be merry! Tomorrow we snuff it! - (Sid James, from 'Hancock's Half Hour') -
Another possibility... Use Something like SmartRipper or DVDX to rip one CHAPTER at a time (which should correspond to different songs), then demux the resulting MPG (with TMPGEnc?) and you should get the audio by itself (probably WAV format), which you can then encode.
Try HeadAC3he (in the Tools section). It'll convert .ac3 to .wav in one step. Good luck.
Freeware for making music videos?
By muffinman123 in forum EditingReplies: 4Last Post: 21st Sep 2011, 05:44 -
which is the best Program for making Youtube 'music' Vids?
By snadge in forum EditingReplies: 1Last Post: 11th May 2011, 14:00 -
Extracting audio from music DVD and burning to CD
By busterbrown885 in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 15:30 -
No audio after making DVD
By Dark Mirage in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 3rd Mar 2008, 15:47 -
making a music DVD
By sathyan in forum Authoring (DVD)Replies: 1Last Post: 16th Jul 2007, 14:30
