    Nov 2002
    New Brunswick, Canada
    I have been looking all over, but I can't seem to find an answer to this.
    I have an mpeg file that is 82 minutes long and therefore will not fit on an 80 minute cd (using a longer cd is not an option with my burner). If I could clip off the credits this file would fit perfectly on one disk. Is there a way to cut a number of frames off of an mpeg without demuxing and converting the files to another format?
    I have also tried splitting the file using moremissingtools, but everytime I split the second file will not work. Plus I wouls prefer to only have to use one disk.
    Can anyone help?
    - Elreeko
    "I have not failed. I have simply discovered what does not work." - Thomas Edison
    Aug 2002
    If you just want to make one fast cut you can d/l the free for 30 days TMPGEnc. It will do what you need.
    In the future if you want to cut a bunch of different places all at once, download the honestech mpeg editor. The trial is not fully functional.
    Nov 2002
    I appreciate the information, but there is just one big problem...
    This is the mac video forum and tmpegenc is only available for windows.
    Is there anything comparable for mac yet?
    - Elreeko
  4. Use mpgtx. It'll do exactly what you want.
    Nov 2002
    I thought mpegtx would only cut a file in to equal sized pieces. Will it actually let me cut a 2 minute chunk off of the end of the file and still leave an 80 piece?
    - Elreeko
  6. Originally Posted by elreeko
    Yes.
    philip
    Nov 2002
    Awesome Thanks for the info. Once I finish my rip I'll try that out.
    Hopefully if will work properly in 10.1.5.
    Thanks again.
    - Elreeko
