I just recently reformatted my hard drive & I have tried Power DVD and also Smart Ripper & Windows media player after reformatting with no luck of playing or accepting to play a dvd.
My system is AMD 2100, 512 ddr ram & WIN XP (with service pack 1)
my DVD writer is a "Pioneer A03" & i live in Australia so my DVD is region 4 "PAL"
"POWER DVD" says : Error Code 8901000f
An internal error has occurred. in the "Detailed" section it only says "This error code is undefined".Contact powerdvd@gocyberlink.com. Please tell us how this internal error occurred in a detailed manner.
"Smart Ripper" tells me : No ASPI adapter available
then it goes on to say some files are still locked!
Win Media Player tells me : that i don't have a compatible DVD Decoder installed on my Pc
can anyone please help me out like possibly where to find the aspi adapter , which DVD decoder i need. How i may be able to resolve this problem, all help is apreciated. thank you in advance
some one out there must know surely, have any of you had this same problem before?
please i would really like some help here as i am not super computer literate.
thanks again in advance for all help -
You need to load the aspi layers for XP you can find them here
http://www.dvd2svcd.org/xp-aspi.zip
if that link doesnt work they are located on the DVD2SVCD page -
Ok i found out that my Power DVD was not installed correctly, like i think some of the registry files or somthing was missing . so after the reinstall, it works but... Do you think i should download those aspi layers? do i need them and what do they do for win xp.
sorry still learning but thats why i copme to this forum.
Power DVD 10 Won't SD DVD From Hard Drive
By wulf109 in forum Software PlayingReplies: 1Last Post: 16th Apr 2010, 02:10 -
DVD drive stopped reading DVDs for a very random reason..
By narutoball in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th Oct 2008, 16:23 -
Menus not shown in DVD Decrypter or Smart Ripper
By EmpireStrikesBack198 in forum DVD RippingReplies: 2Last Post: 11th Jun 2008, 17:48 -
Play dvds from dvd drive or from hd to save battery power?
By denise4gb in forum Newbie / General discussionsReplies: 1Last Post: 2nd Nov 2007, 21:29 -
Smart ripper help
By holland11 in forum Authoring (DVD)Replies: 4Last Post: 13th May 2007, 02:15
