Hi, i am trying to encode a SVCD to VCD with TMPGEnc but failed several times. I have a SVCD file on 734MB i tryied to burn to a 800MB cd but did not work please tell me what to do i have been trying to fix this prob for 2 days without any result. Many thanks in advance.
Results 1 to 13 of 13
you can fit over 800 MB of SVCD on a 800MB disc.Originally Posted by Pardesan
how are you trying to burn it?
look through the guides here, or, the easiest way is to use VCDeasy to author an image(uncheck the perform compliance checks box), and then use daemontools to mount the image as a virtual drive, and use whatever program you like to copy the disc to your CDR(W).
I personally use either Nero or Clone CD, and both work great for this.
good luck!what are you askin' me for...
I'm an idiot! -
Well its a SVCD file of 734MB, using NERO 5 v5.5.9.17 , i think its something to do why my cdrw becuase it cant read the 800MB cd.
i have SONY 10X 4X 32X, maybe its too old
looking at those speed Id say the burner is a little old, to memory 800 meg is a 90 min cdr ? is that what your using?
if your using the 90 min cdr then your burner needs to support overburning, possible as your burner is a older one it doesnt do this and therefor you wont be able to burn to that disk.
on the other hand if it does support the overburn process then in nero's menu select,
File --> Preferences then click on the tab that says Expert Features and check the Enable Overburn box, then enter the correct maximun cd length.
Then click on the General tab , and enter the approrpriate numbers into the box there Yellow Marker= 90 min Red= what ever you want to set I have Mine set at 99, click apply and then ok.
When you burn nero will first pop up a message saying that your disk isnt big enough, then a second will pop up asking if you would like to overburn ( this is allowing that your burner can physically handle overburn if not then this will not work)
I hope this has helped
I just recently bought a new burner cause My old one didnt support overburn so I know your frustration. Just stay at it
ciao
TLTwThe Hellsing family will purify this world... -
well i tryied but not working coz my cdrw is unable to read the cd
anyway thanks for all your help ppl
very appreciated. i'll buy new burner too
Regards Pardesan.[/quote] -
just check that the burner supports overburning before you buy it
I know the lite-on 48X 12x 48x does cause its what I use, the latest LG burners are supposed to be pretty good also with overburn support but I cant talk from experience on this burner.
LaterzThe Hellsing family will purify this world... -
yeah i will, but i have another question, and i have been working to encode a SVCD to VCD with TMPGEnc but failed as dumb i am so
first of all it took me 8 hours to encode that file but still dont work.
actually i wan to burn to a 700MB cd but the file is about 734MB?
please tell me a simple way to encode the stupid thing.
Pardesan -
even though that is larger it should still be able to burn onto the cd without too much trouble. I have burned 795 meg SVCD onto a 700 meg disk.
ciao
when you burn a Video CD your burning in Mode2Originally Posted by Pardesan
so a 700MB CD will hold 800MB
weird i know.. -
Okies, i'll try to burn lets c then. Can i do with NERO the new version?
does it matter if its a SVCD or VCD?????????
rEGARDS
Nero should be able to burn it. just select new, and (S)VCD, and then load your mpeg.
some people have problems w/Nero, so they follow the method I described in my first post.
use VCDeasy to author an image(uncheck the perform compliance checks box), and then use daemontools to mount the image as a virtual drive, and use whatever program you like to copy the disc to your CDR(W).what are you askin' me for...
I'm an idiot! -
That workes
Thanks to everyone ...........and you people are doing really good joob
Regards -
I can usually squeeze 815mb on my fuji cd-r, i use nero to burn and never had any problems w/ overburning, ya just got to figure out what your doing.
What is The Best Script To Encode a Resized VCD Rip in Megui??
By a6hatesme in forum Authoring (VCD/SVCD)Replies: 10Last Post: 27th Mar 2012, 19:47 -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 13:09 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 10:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 20:25
