Hi there all,
can I capture from TV using the following way :
Use a TV card to get the TV signal on my PC and then use another card (say PC30+) to capture from the TV.
Is that possible ?
What make is your card? It may already have a capturing program with it.
What you are talking about doing is:
1. RF signal in
2. Send to tuner
3. Convert output to digital
4. Send to video driver
5. Send back to card
6. Convert back to analog
7. Send to video out
8. Analog video signal in
9. Convert to digital
10. Send to capture card driver
11. Send to capture card software
Do you think after all that you'll end up with a better picture?!?!
You would be better off just connecting a good VCR to your capture card. The tuners in VCR's are usually better than average and you can also capture taped programs.
RF
Capturing Help
By Kyoji24 in forum Capturing and VCRReplies: 4Last Post: 23rd Apr 2010, 07:37 -
What are you capturing?
By ryangarfield in forum Capturing and VCRReplies: 10Last Post: 20th Apr 2010, 15:16 -
Capturing help.
By fuseek in forum Capturing and VCRReplies: 0Last Post: 6th May 2008, 10:49 -
Looking to start HD capturing...
By RockWood610 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 2nd Apr 2008, 18:42 -
Capturing in HD
By The Sumerian in forum Capturing and VCRReplies: 1Last Post: 7th Jun 2007, 12:40
