hello.
im trying to make a svcd with switchable subtitles,
i was told to use subrip and WinSubMux to do it.
i now have the subs saved on "philips" format (svcd)
when i try and load the mpeg + the subs into WinSubMux
and mutiplex them, i get an error message saying
"ph is not a valid integer value".
can anyone tell me why?
nothing works, maybe im doing somthing wrong?
thanks
HELL AINT A BAD PLACE TO BE
I had the same problem when I first tried making SVCD subtitles. The winsubmux format is almost, but not quite, Phillips format. Phillips format has a header that winsubmux can't use. If you used subrip to get the file, it will start with something like this:
Delete everything above the first subtitle BMP line (including the[LIST] header) and try it again. submux/winsubmux uses the same format for individual subtitles, but it chokes on the additional information that Phillips SVCD designer (or whatever it's called) uses.Code:# PHILIPS SVCD DESIGNER 1.5 - 2.0 SUBTITLES FILE # # GENERATED BY SUBRIP 1.035 on 9/1/2002 1:44:20 AM # [HEADER] TITLE FRAMERATE NTSC DROPFRAME YES CONTRAST (0 15 15 15) [LIST] sub00001.bmp 00:00:58:01 00:01:00:02 120 050 302 382 ...
thanks for your reply sterno,
ill try what you said, hope it works.
thanks againHELL AINT A BAD PLACE TO BE
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
Winsubmux error. Plus submux not muxing
By Codecoder in forum Authoring (VCD/SVCD)Replies: 1Last Post: 12th Jul 2008, 22:30 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
