Results 1 to 11 of 11
  1. How can I extract the audio from a vcd? (convert .dat file into .wav or .aif) :o
  2. Try this link to convert the .dat to a .mpg
    http://www.vcdhelp.com/convertdat.htm
    And this one to extract the audio...
    http://www.vcdhelp.com/virtualdubaudio.htm
    GGS.
    Eat! Drink! Be merry! Tomorrow we snuff it! - (Sid James, from 'Hancock's Half Hour')
  3. Save the dat file to your hard drive, rename as mpg. Open tmpgenc and select the mpg file as your video/audio source. Click file->output to file->wave file.
  4. Are the .dat files just standard .mpg files renamed for the prupose of the VCD then?
    GGS
  5. Thanks a lot guys! I'll try everything you've suggested. I'll keep you posted. :)
  6. This is 4 guitar_george_skank;
    actually I just want to extract the audio from a vcd & save it either as .wav or .aif for the purpose of recording it as audioCD.
  7. Just use the TMPG method described by craigtucker then. That should work a treat. Should of thought of that myself
    GGS.
  8. Thanks again. I'll do that.
  9. I tried the virtualDub but the audio quality isn't that as good as the original .dat file. It sounds like there's reverb or somewhat erratic. Anyway I'll try the tmpgenc, I wish it works.
  10. What settings did you use in VirtualDub? I presume you chose No compression (PCM) and didn't change the sampling rate? Anyway, TMPG shgould do the job just fine. Good luck.
    GGS.
