I have 2 separate movies that I want to burn onto 1 cd. Should I use chapters or menus to so the dvd player can go directly to the second movie. What is the difference between menus and chapters? Thanks
ps. forgot to mention, i am trying to make a vcd
With a menu, you get a graphical interface (that you create) that comes up when the disc first starts playing. From there, you choose the menu option and the movie will start playing. Using a chapter is much like how you would change songs on a music CD, you would have to push the "next" button to skip the current movie (provided that you don't have any more chapters within the movie that you can skip to).
It really isn't a mutually exclusive thing... You can use both!
http://www.vcdimager.org/guides
Regards.Michael Tam
w: Morsels of Evidence
Play All option STILL goes to menu after each chapter
By stevencarl in forum Authoring (DVD)Replies: 1Last Post: 5th Oct 2011, 13:17 -
Best way to add pop-up chapter menu?
By mikeveli20 in forum Authoring (Blu-ray)Replies: 2Last Post: 4th Oct 2011, 00:08 -
Menu chapter and/or whole movie.
By rpvliet in forum Authoring (DVD)Replies: 2Last Post: 21st Aug 2011, 12:10 -
How to create chapter menu without thumbnails
By truongv0ky in forum Authoring (Blu-ray)Replies: 3Last Post: 4th May 2011, 15:05 -
DVD Menu with Chapter and Menu Template.
By big-boo in forum Authoring (DVD)Replies: 3Last Post: 17th Mar 2008, 06:20
