I have been having lock up problems for ages. System freezes at random times during capturing. If i did a fresh install of winxp - it would capture fine for a few times then the lockups would start again. I have tried everything - via 4in1 drivers, pci latency drivers, other capture cards. This is driving me mad. The lock ups only occur if video and audio is captured together. capture video fine for hours on its own.
Is this a problem with via chipsets or winxp maybe. Please, if someone has had the same problems and managed to fix it - please let me know.
p4 2.20g - ecs p4svxd2 (via chipset) motherboard
512 meg ram - 120gig 7200rpm hd
i have used avertv and wintv capture cards
This probably won't help a lot but may get you going in the right direction
Do a search through the capture forum for Via chipset. When I was looking for something else I saw a few threads on this chipset causing problems and I also saw something about a patch. Sorry I can't remember exactly where......
cloning winXP system disk problem
By deejay.2001 in forum ComputerReplies: 1Last Post: 15th Jun 2009, 16:54 -
System.UnauthorizedAccessException error after WinXP SP3 install
By scoop46 in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 20th Oct 2008, 10:03 -
how to format cloned system hdd with winxp
By deejay.2001 in forum ComputerReplies: 4Last Post: 22nd Jun 2008, 08:17 -
computer freezes, won't allow WinXP install
By iThinkYouBrokeIt in forum ComputerReplies: 15Last Post: 13th Aug 2007, 19:07 -
System freezes while recording DVD-T
By gabier in forum DVB / IPTVReplies: 7Last Post: 23rd May 2007, 16:38
