i have a captured video that i want to put music to and burn to a dvdr....i have tried mp3 and wave but they didn't seem to work....what must i turn this audio file into??? and what tools should i use to encode the audio? thanks......i am useing dvdit or neodvd to author and burn...either program will work if i have the right audio....
Use this program to encode to .ac3 Best thing to use for you I guess, I use it all the time. Be sure to set the sampling rate to 48000. You will also need besweet.
http://www.doom9.org/Soft21/Audio/AC3Machinev0.41.zip
http://www.doom9.org/Soft21/Audio/BeSweetv1.4.zip
Guide is located here:
http://www.doom9.org/ac3machine.htm -
i tried the doom9 link but it gave the error....do i have to register to that sight???
Seeking help - convert/burn .OGG(audio only) 5.1 to DVD-Audio 5.1
By cinesimon in forum AudioReplies: 0Last Post: 18th Oct 2010, 18:28 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 13:40 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 06:03 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
Ripping Audio with ImTOO DVD Ripper Platinum 4 vs DVD Audio Extractor
By xtreme469 in forum AudioReplies: 0Last Post: 29th Sep 2007, 03:06
