  1. I ripped with SmartRipper and now I am trying to burn with Nero but when I try to drag the Video Files into the VIDEO_TS folder it says something about the file being bigger than 2GB? How do I fix this?
  2. BTW, the file size for the .m2v file says 4.35 GB, isnt this acceptable for a 4.7 GB disc?
  3. BiggNewt -
    you can't just burn a m2v file directly ( and if you got a m2v file, where's your AC3 file ? ) to a DVD as it will not work, it need to be authored, Nero does not author DVD's it just burns them. The DVD file structure specifies that the vob files be 1Gb each no bigger. Check the guides here or at doom9.org to see how to DVD to DVD-R
