Got all the dolby digital and thx vobs from
http://www.cinenow.com/uk/vobtrailer.php3.
Question: Now how do I make those cool intros part of the dvdr authored output so they will play at the beginning of the movies??? I've copied the desired vobs to the video_ts folder of the movie title set, but it seems there needs to be something else done to instruct it to play and play in the right order...help!!!
masterpug
Demultiplex the vobs into video and audio streams using the demultiplex option of TmpGenc tools. You can now remultiplex into a .mpg file if you want or if your authoring app accepts elemntary streams just use them as they are. Maybe make them the 1st play item on your DVD.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
extracting SUP format subs from vob title set.
By davexnet in forum Authoring (DVD)Replies: 2Last Post: 26th Sep 2010, 19:29 -
How to add a chapter or a title to ONE ONLY TITLE in a DVD?
By coxanhvn in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2009, 22:16 -
How do I set chapter points in an already authored DVD?
By midders in forum Authoring (DVD)Replies: 6Last Post: 25th Sep 2008, 17:57 -
Cannot convert 1 title to ipod from self-authored DVD...
By BeachNut in forum DVD RippingReplies: 2Last Post: 4th Feb 2008, 11:48
