Results 1 to 12 of 12
  1. I was trying to burn CD from BIN (cue) file with no success. I burned CD without any problems on my Buslink CD burner from same source. I don't have exact error message now, but .... Anybody with same issue ? Is it sofware or hardware issue ? Making CD as a compilation is working fine.
    Aug 2001
    Finland
    This is what I have experienced this far:
    Tried to burn an SVCD image in DAO mode: failed right away
    Tried to burn an SVCD image in DAO/96 mode: failed in the end, but I think this was just becausde the drive isn't that good in overburning. However, I had no problems burning this image with my Yamaha 16x CDRW.
    Burning images should work when using DAO/96 mode, if the image is small enough to fit on a cd without overburning.
  3. I am not sure what DAO mode is But I will try that duringf this weekend and I will update this post with result.
    Thanks.
  4. OK. I finally have chance to look into this again.
    I have 2 files (bin file is data CD not SVCD)
    abc.cue
    abc.bin
    My *.cue file have this in it
    FILE "ABC.BIN" BINARY
    TRACK 01 MODE2/2352
    INDEX 01 00:00:00
    What do I need to do to burn it with Nero and Sony DRU-500A ? I have to add that I was able to use same files with success on my Buslink CD burner. So is this issue with Sony drive ?
    And.... Yes.... I tried "File / Burn Image"
    This is from log...
    ..Burn process started at 4x (600 KB/s)
    ..Invalid field in parameter
    ..Could not perform start of Disc-At-Once
    ..Burn process failed at (600 KB/s)
    Any ideas ??
    Aug 2001
    Finland
    So did you try burning in DAO/96 mode?
    That was exactly the error I got when tried to burn in DAO mode.
  6. Originally Posted by RoopeT
    Could you please explain me how to do that ???
    I don't burn SVCD disk and size of bin file is only 236 MB.
  7. Originally Posted by donpedro
    This is from log...
    Any ideas ??
    I get same message in nero when trying to burn to 1X princo dvd-rw media.
    I cant successfully burn an .iso at all.
    The drive sux!
  8. scaftag have you ever seen any post with succesfull image burn on this drive ? Is it even possibe ?
  9. Nero isn't the best program to be burning CUE/BIN images with anyway...
    It doesn't seem to me (from the CUE sheet) that you are burning a S/VCD?
    In any case, have you tried using CDRWin or CDRDAO / VCDEasy to burn the CUE/BIN image?
    Regards.
    Michael Tam
    w: Morsels of Evidence
  10. No, I am not trying tu burn SVCD.
    No, I didn't try CDRWin or CDRDAO. I didn't see these programs listed here in Tools page (only VCDEasy).
    Isn't VCDEasy only for VCD or SVCD ?
    Is there any logical explanation why same files can be burned wit same version of Nero by Buslink CD burner but not Sony DRU-500A ?
  11. I am having this EXACT same problem with the new Pioneer DVR-105, and I am trying to burn a vcd bin, cue image....
    I have also found out that this happens even when encoding my own mpeg and using nero to create the vcd
    I have tried cdrwin 39.b, fireburner, alcohol, and Nero and all programs give the same result...
    I suspect we need some firmware upgrades...
    Doug
  12. Originally Posted by donpedro
    CDRWin: http://www.goldenhawk.com (demo that can do 1x burning available)
    You can use VCDEasy as a GUI to CDRDAO which is an open source / free CD burning proggy (capable of burning CUE/BIN images). As such, you can use VCDEasy / CDRDAO to burn a CUE/BIN image of anything (INCLUDING that of S/VCDs).
    It could be a firmware problem as kingfenix suggested...
    Regards.
    Michael Tam
