Hello all,
I am trying to rip a friend's dvd and it is in play back the motion is slightly slow, especially when the camera/picture is panning, as if I am using the wrong frame rate. However, the DVD is in PAL format as diplayed by smart ripper and on the DVD cover and I used this format.
specifications : (in tmpgenc)
Video-CD PAL (MPEG-1 352x288 25fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
In the video TAB:
Motion serach: high quality
(doesn't allow me to change these values)
Bitrate: CBR
Aspect ratio 4:3 625 line (PAL)
In the advanced tab:
Video source type: interlace
Field order: bottom field first
Source aspect ratio 16:9 625 line (PAL)
Video arrange method (full screen (keep aspect ratio 2)
GOP structure: I-1, P-5, B-2
I appreciate anyones help and time
Thanks :P
Quick answer...IF you mean playback is slow from the DVD drive, insure your DVD drive is using DMA mode and not PIO...If you mean from the encoded video, most DVD players like Intervideo WinDVD or DVD Pro have a setting that allows you to speed up the playback or slow it down...If not one of those two, sorrry I couldn't help.
slow HD playback even though i have an okay PC (pic)
By edgeofthecosmos in forum DVB / IPTVReplies: 28Last Post: 30th Jul 2011, 21:17 -
Very slow playback software
By bryankendall in forum Newbie / General discussionsReplies: 2Last Post: 26th Jun 2010, 16:30 -
Slow AVI playback?
By JeffM in forum ProgrammingReplies: 10Last Post: 24th Apr 2009, 07:44 -
Slow playback on HD MP4 video
By excelsion in forum Newbie / General discussionsReplies: 3Last Post: 24th Jan 2009, 00:22 -
Slow MKV 1080p Playback!
By The_WRATH in forum Newbie / General discussionsReplies: 3Last Post: 19th Aug 2008, 14:50
