I finally found a flash utility that will let you flash back to older firmwares without doing surgery on your drive. I had 1.33 and flashed back to 1.31 and tried a couple of other hacked ones and this flash utility works. Just use the flash utility posted at the top with any of the other firmwares and it works great. It searches out the hardware keys and the flashes whatever firmware rev. you want. Sometimes it can take a while so once it starts don't touch. The flash from 1.33 to 1.31 took about 1 minute but one of the other ones took 15 minutes, but it worked.![]()
Here's the addy that has the utility and pretty much all of the firmwares out for the A04 and the A03.
http://firmwares.co.uk/
If you havn't already you might want to post this on the DVD writes as a comment on these drives.
Samsung BD-P1590/BD-P1600 Foreign Firmware Flash/Region Free Issue
By 5arge in forum DVD & Blu-ray PlayersReplies: 12Last Post: 15th Apr 2012, 20:32 -
ADS Pyro A/V Link - Firmware u/g to fix VHS dropped frames
By pbanders in forum Capturing and VCRReplies: 16Last Post: 24th Mar 2011, 23:40 -
Is it possible to flash firmware onto a non-original DVD burner???
By suomalainen in forum Newbie / General discussionsReplies: 1Last Post: 12th Dec 2009, 17:17 -
DVR-533h Firmware help
By dcbj in forum DVD & Blu-ray RecordersReplies: 0Last Post: 12th Oct 2009, 08:30 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 08:20
