    7th layer of hell
    can anyone help me out with a birate calculator formula? i got one from the rip different message board but i don't think the bitrate always comes out properly.. i've had success with the one in ffmpegx but i want the actual working equation itself for coding purposes.
    http://www.macdvd.org/ubb/Forum1/HTML/000035.html
    that is the link to the rip different thread about a formula but it often gets different results from ffmpegx so im not 100% confident in it.. either that or im just not using it right.
    As below, so above and beyond, I imagine
    drawn outside the lines of reason.
    Push the envelope. Watch it bend.
    Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind.
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    There are some at the top of this page.
    http://www.vcdhelp.com/tools
    7th layer of hell
    i dont want bitrate calc programs.. i already have plenty of em.. i want the actual formula itself to calculate the bitrate so i can implement a calc into afropic
  4. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Originally Posted by Doc Boese
    Use this formular to calculate your bitrate:
    Videobitrate = (M x (L / L1) - A) / 100
    M = Lenght of the whole movie
    L = Size of the Medium you like to use in kb (e.g. 800 MB = 800.000 kb)
    L1 = Minutes you like to have on the Medium in seconds
    A = Audiobitrate in kb
    If the movie has a length of 90 Minutes is M = 5.400
    If you like to use two 700 Mb CD-R's then is L = 140.000
    If you like to rip the movie as an SVCD containing 50 minutes for one CD is L1 = 3.000
    If the bitrate of the sound should be 224 kb then is A = 224
    In that case ...
    Videobitrate = (5.400 x (140.000 / 3.000) - 224) / 100
    You should use 2518 kb/sec to rip the movie.
    This formular will work for every kind of movie.
    7th layer of hell
    muchas gracias... i tried to search for a thread that had the post alreaady cuz i was sure it was here somewhere but didnt have much luck.. either way now i can add one very easily. its kinda annoying not having on built in, kinda takes away from the all-in-oneness (if thats a word)
  6. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Yeah, the topic title was something about ac3 files, but I remembered it from earlier. Sounds like the program is coming along nicely. Keep up the good work.
  7. tgpp: Is there a way for me to calculate (Formula??)how long of a moive that I can put my DVD-R?? I am capturing from VHS using ATI AIW with Virtual Dub, Huffuv@720*480 PCM audio 44khz. My tape is around 2 hour and 30 min. long. Is there a formula that I can follow so that I can calculate how many DVD-R I would need, and how long each DVD-R is going to be ?
