Hello all, was wondering what the average bitrate of the video that everyone usually gets when converting an .AVI into an svcd compliant MPEG and burned onto 1 - 80 minute cdr. This is using 224 bit for audio and with an approx 45 minute movie file.
The reason i ask is that using tmpeg i usually average about 2100. However, i downloaded a .rar file and then extracted, and then burned the .bin, and eventually it was an svcd of approx the same length (45min) and the quality was very good and the bitrate for the video was about 2500???.....So that leaves me wondering, how can i obtain that quality too, am i doing something wrong?
Any help much appreciated. Thank You
Rapplin
The bitrate dictates the file size. As simple as that. For a 45 min SVCD with 224 audio, the following video bitrates apply (give or take a few bits):
74 min CD - 2000
80 min CD - 2182
90 min CD - 2482
Maybe that figure of 2500 was the maximum rate used? How did you get that figure?
If you use VBR instead of CBR you'll get better quality at lower bitrates.
A bitrate of 2500 will get you around 39mins, 45 secs on an 80 min CD.
GGSEat! Drink! Be merry! Tomorrow we snuff it! - (Sid James, from 'Hancock's Half Hour') -
Yes, that the reason high motion movie is better in VBR than CBR.
Those few big scenses normally just squeeze by at VBR high of 2520,
instead of have much of macroblock at CBR of 2200. -
Sorry for asking, but when i encode my movie into an SVCD compliant mpeg using TMPEG, where do i go to choose VBR instead of CBR for a high action film?
HCenc 2nd pass, what to do about: "*** INFO, adjusting average bitrate..."?
By jclampy in forum Newbie / General discussionsReplies: 14Last Post: 5th Jan 2012, 14:30 -
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
hanbrake average bitrate
By scarlac in forum Video ConversionReplies: 4Last Post: 12th May 2010, 13:35 -
average settings for 3GP?
By mberndt100 in forum MacReplies: 2Last Post: 19th Nov 2007, 08:07 -
VBR (2 pass, average bitrate) Encoding for DVD-9
By jcm0320 in forum Video ConversionReplies: 3Last Post: 15th Aug 2007, 09:44
