I have been fortunately successful putting most DVD's into SVCD format on two CD-R's, which is great, because I don't want more then two CD-R's per movie, even if it does mean some quality loss. But the most I have ever put on one SVCD/ 80 min CD-R is about 806 MB's/mode 2, or 67 minutes of actual film time. The Bit-Rate for that much length of film was about 1525 kbps. I was wondering how much worse the picture quality would be if I tried to fit a 120 minute SVCD on ONE CD-R. Being that the bitrate would be approximately 700 or so, would that at least give me VHS-like quality? I guess at that bitrate, it really wouldn't be an SVCD, but more considered a VCD, right? Being that I am using DVD2SVCD/TMPGenc, and it takes sometimes 14 hours to encode, I haven't tested it.
But if I did try it, should I change the output from MPEG-2, to MPEG-1, or would it not make a difference either way? If anyone knows, please help me out on this. Thanks
Results 1 to 1 of 1
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 03:26 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38
