I downloaded a mpeg2 video file, which has excellent volume, but the audio is very faint.....turning volume up all the way still yields whispering dialogue. i don't have a divx or avi file, just hte mpg I downloaded, so using virtualdub won't work. I s ther a way to take the demuxed audio, boost the volume, then recombine it with the video?
If I use tmpgenc to demux into separate audio and video, I can use project wizard to recombine, and use audio settings to boost audio volume, but the time to take to recombine using 2 pass vbr or even cbr takes many many hours. Is there a way to take the audio and boost volume, then mux it with the video using the mpeg tools in tmpgenc?
Thx
You need to seperate the streams. tmpeg--> mpeg tools--> demultiplex, save the .mpa or.mp2 file. then you need to convert that to a .wav. tmpeg can do that as well. then you'll need to normalize the audio in a program like cooledit or soundforge, then convert that back to an .mp2(I suggest toolame) then just to a multiplex back with the video stream.
depending on the size and speed of your system it could take a few min or longer. Just don't re-encode the whole file again. The project wizard is to re-encode, use mpeg tools from the file menu to access the the multiplex option"The software said Win XP or better, so I Installed Linux"
AVI file volume increase.
By seven1970 in forum AudioReplies: 8Last Post: 31st May 2013, 17:07 -
Increase VOB file volume
By boren1969 in forum Newbie / General discussionsReplies: 2Last Post: 5th Dec 2010, 23:19 -
how to increase volume of a mkv file
By wolvie77 in forum AudioReplies: 3Last Post: 8th Nov 2010, 15:54 -
volume increase
By natty in forum Newbie / General discussionsReplies: 1Last Post: 18th Jan 2008, 11:08 -
Trying to find a program I once had to increase volume on a audio file
By natty in forum Newbie / General discussionsReplies: 6Last Post: 18th Jul 2007, 15:57
