I encoded Spider-Man and the file size is 3.5, what can I do with that extra space? Add some extras or a menu or something? And how would I go about doing that?
if i was you i would try to fill the disc with the film by encoding it a lot bigger than 3.5.
the bigger the better for qaulity pictures. -
was the film 3.5 to start. if so leave it as it is cause you cant get better.
if the film was bigger how did you encode it in the first place. -
Hmm. I ripped Spider man without encoding. If you remove other audio and title. You will get just below than 4.3 Gb so you will not lose any quality. I used Ifoedit.
No need to encode Spider-Man. Just do the following:Originally Posted by BiggNewt
1. Smartripper or DVD Decrytper
2. IfoEdit - VOB EXTRAS to strip off everything except ENGLISH and Dolby Audio.
3. Exit IfoEdit
4. IfoEdit and GET VTS_SECTOR to align everything.
5. burn NERO
There are plenty of GUIDES on this site to give the details.
Spider-Man starts off at 5.5GB's. After doing the above process you end up with 4.3GB's which fits on 1 DVDr. I have done this!
11 Extra GB in Encore
By koberulz in forum Authoring (Blu-ray)Replies: 3Last Post: 6th Sep 2010, 06:08 -
cd extra / enhanced cd
By cd090580 in forum Newbie / General discussionsReplies: 3Last Post: 4th Feb 2009, 14:22 -
Is VCD/DVD disc space limited by time, or space?
By pingosimon in forum MacReplies: 6Last Post: 14th Jul 2007, 19:55 -
Hard Disk Space When Encoding
By Em in forum Newbie / General discussionsReplies: 8Last Post: 21st May 2007, 12:35
