I grok how to convert using TMpegEnc etc, but I have several movies that are in two DivX parts. Is there a program that will take multiple input files and span them over multiple output chunks?
Why not use TMPG to encode each divx part to fit on one CD? Then you can set up each encode job and put it in the batch processing.
GGS.Eat! Drink! Be merry! Tomorrow we snuff it! - (Sid James, from 'Hancock's Half Hour')
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 12:23 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
Deinterlace first or multiple times? Encoding source to multiple formats.
By greyfalcon in forum Video ConversionReplies: 1Last Post: 12th Apr 2011, 04:39 -
Batch hard encode multiple language srt to multiple videos
By clonius in forum SubtitleReplies: 4Last Post: 15th Jul 2010, 14:06 -
Merge multiple VOB then convert to DivX
By submanic in forum DVD RippingReplies: 24Last Post: 19th Sep 2008, 14:39
