what is the most reliable dvd-r media for an imac g4 with built in superdrive writer
Most reliable? Apple media hands down, but its about $5 each in packs of 5. The apple Superdrive and the DVR-A03 and A04 are the same thing (model depending on the time you purchased your unit) If you dont mind burning at 1x you can also try the Primedisc Riteks over at shop4tech, I've had good luck with them in my A04 so far and they range from $2 each to $1 each depending on how many your willing to buy, I suggest starting with a small pack first.
software for an imac
By marlo in forum MacReplies: 11Last Post: 13th Aug 2011, 09:49 -
DirecTV HD to iMac?
By jcoconnor in forum MacReplies: 0Last Post: 5th Apr 2009, 16:36 -
how can i record vcd on imac?
By Ade007 in forum MacReplies: 4Last Post: 9th Aug 2008, 15:34 -
Dell or imac
By fairytale00 in forum ComputerReplies: 17Last Post: 29th Mar 2008, 13:51 -
Problem with imac G4
By matw79 in forum MacReplies: 1Last Post: 14th Jul 2007, 07:55
