  1. Hi there,
    I've searched through the forum but have been unable to find an answer to my query, I apologise if it's been gone over before.
    I'm following the guide on this site to convert with DVD2SVCD (the one with Spiderman) and all goes well, it looks like it works and I get no errors.
    When it has finished I get these files in the specified folder:
    Encoded_audio_1.log
    Encoded_audio_1.mp2
    Encoded_Video_TMPGEnc_NTSC.mpv
    Extracted_audio_1.wav
    TMPGEnc_Project_file.tpr
    My question: what do I do with these files?
    Thanks for your help!
    V
    Aug 2001
    Finland
    Encoded_audio_1.mp2 is your encoded audio stream
    Encoded_Video_TMPGEnc_NTSC.mpv is your encoded video stream
    You should also have some .mpgs and .bin/.cue files somewhere, check first your DVD2SVCD settings if you have for some reason disabled creating these / they're created onto a different folder.
    Anyway, you can multiplex your video and audio streams with bbmpeg and then burn the multiplexed file(s) with Nero.
