I am trying to fix an AVI with VirtualDub (1.4.11) by doing:
Audio, Direct Stream Copy
Video, Direct Stream Copy
File, Save As AVI.
The end result is an AVI half the size of the original. When I play the corrected AVI at some point I have no video more, only audio.
Can I fix this, or is the AVI to broken to be fixed?
Have you scanned the video stream for errors first. Sounds like there is a freeze in the video.
Yes, first I scanned for errors. There were a few bad frames, bat alot of frames that were good but undecodable (or someting like thatOriginally Posted by craigtucker
After the scanning I tried to fix it as described. -
It sounds like there were so many frames undecodable that when you saved as .avi, virtualdub has cut them out and left the .avi unusable. Unless you can get another version of the .avi then I think your stuck.
Maybe this link can help...
http://www.am-soft.ru/articles/drepair/
GGSEat! Drink! Be merry! Tomorrow we snuff it! - (Sid James, from 'Hancock's Half Hour') -
Originally Posted by MadSaid
I usually have this problem also when I have a file with a HUGE amount of bad frames. Download "vdub_mp3_freeze" and follow this guide right here:
http://ww2.vcdhelp.com/forum/userguides/117930.php
Hope That Helps!!!
:P
I solved the problem with vdub_mp3_freeze. Thanx puertorican138.
guitar_george_skank: Thanx as well. I read the guide on how to fix DivX eith AVI Edit. May use this one the next time, cause I don't loose the bad frames. I can realy fix them!
fixing suffled AVI
By fred3f in forum EditingReplies: 7Last Post: 13th Jan 2010, 22:54 -
Reparing or fixing AVI files
By 1234567 in forum EditingReplies: 26Last Post: 16th Feb 2009, 17:53 -
Overscan, Fixing the problem without Editing the avi files?
By Gabriel87 in forum Authoring (DVD)Replies: 26Last Post: 21st Nov 2007, 19:41 -
Fixing Color Problem
By Akai-Shuichi in forum RestorationReplies: 19Last Post: 12th Oct 2007, 06:57 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 08:44
