I wanted to convert an Rm video file to VCD version
but how can i do it or what software i need to do that
thanks thanks
I'm fairly certain that there is a guide already present on the VcdHelp site, but I'm too lazy to go look so here's a mini-guide. basically, the steps would look something like this (*big caveat):
1. convert the RM to AVI using Tinra (Tinra is freeware, but you must already have a version of RealPlayer installed -- free version or otherwise -- because Tinra uses Realplayer to do read part of the conversion). I'd use RAW uncompressed AVI video output (or HuffYuv, or some other lossless codec) since you dont want to do any lossy compression during the intermediate steps.
2. now use TMpgEnc (or whatever your favorite VCD maker is), import the AVI, set all the important options yourself or use the project wizard, and create.
3. burn with your favorite burning app. I like Nero, ymmv.
*Ok. time for that caveat:
I'm not entirely certain that TMpgEnc will create a true VCD from the AVI since the AVI will have a screwy framerate, thanks to RM's tendency to use variable framerates. I think it should compensate (by adding duplicate frames), but I'm not sure.
-s.
Where may I get the last version of the x264 - 64 bits version codec?
By daniel827 in forum EditingReplies: 5Last Post: 27th Dec 2011, 19:55 -
Mac version of VLC is less functional than the Windows and Linux version
By HitTheRoad in forum MacReplies: 12Last Post: 30th Oct 2011, 04:48 -
SUPER version 39 is broken - reinstall older version?
By castalla in forum Video ConversionReplies: 7Last Post: 3rd Nov 2010, 19:20 -
Is the 'academic version' different from the commercial version of Vegas 8?
By jbigfoot in forum Newbie / General discussionsReplies: 2Last Post: 16th Apr 2008, 01:19 -
where to download old version of dvd fab??? error in new version
By willhenderson in forum Newbie / General discussionsReplies: 1Last Post: 1st Dec 2007, 17:00
