usually I use the frame server fonction of virtual dub to re-encode XVID files into divx 5.02 (not for the quality but for the compatibility) before encode them in TMPGenc to MPEG2 format.
But recently Tmpgenc send me a "unsupported file" message, and I can't use this method anymore.The frameserver looks working fine, I can encode the XVID with VDUB in a 5.02 avi file. Then I can transform the 5.02 avi in MPEG 2 with TMPG. To be clear :
* XVID --> Divx 5.02 via frame server (VDUB) --> MPEG2 (TMPGenc) : not working
* XVID --> Divx 5.02 in avi file (VDUB), avi --> MPEG2 (TMPG) : working
* Divx 3 or 4 --> Divx 5.02 via frame server (VDUB) --> MPEG2 (TMPG) : working
This is the same when I'm try to include subtitle inside the video before encode in MPEG2 with the VDub's frame server and the subtitler filter.
where is the problem ?
Hardware Frame Server?
By therock003 in forum Newbie / General discussionsReplies: 0Last Post: 27th Nov 2011, 09:51 -
Mplayer as a frame server? Pipe to file?
By RogerTango in forum Video ConversionReplies: 2Last Post: 10th Sep 2011, 10:23 -
frame server doesn't work in Premiere CS4?
By ivanadit in forum EditingReplies: 0Last Post: 6th Jan 2009, 14:46 -
VDub - Frame Size Problem - Huffyuv-2.1.1
By cnolan011 in forum Capturing and VCRReplies: 8Last Post: 24th Oct 2008, 21:54 -
Vdub frame serving to CCE ?, UPDATE ..Fixed the Error
By theewizard in forum Video ConversionReplies: 15Last Post: 1st Feb 2008, 00:24
