i was wondering.. i'm about to buy the sony flatscreen from best buy with the 24 months interest free financing, and i was wondering if divx would look good on it. the thing is, i'm sure you all know how television disguises any artifacts cuz tv is such low quality... but.. with the flat, it's so badass, that i'm wondering if the artifacts will be any more noticeable or if it would only look better.![]()
I just got a 32" toshiba flat screen, and I definitely can see the artifacting that is normally hidden on lesser quality tvs.. that being said, you should still get the sony... don't base you decision on how divx looks, b/c if that's all you care about, get a cheaper tv.. the sony is going to look better for EVERYTHING else.
Best way to connect PC to SONY Trinitron Wega FD CRT TV
By snsd in forum Newbie / General discussionsReplies: 2Last Post: 29th Dec 2011, 09:07 -
Sony Grand Wega/Blu-Ray Set up
By mngwdw in forum DVB / IPTVReplies: 8Last Post: 16th Dec 2008, 14:05 -
Problem with Sony Wega KDF-E60A20 ??
By ofield1 in forum DVB / IPTVReplies: 1Last Post: 10th Mar 2008, 10:45 -
Sony Wega Digital signal
By iceironman in forum DVB / IPTVReplies: 2Last Post: 25th Feb 2008, 11:38 -
Laptop Via VGA -> Sony Wega LCD Via??
By ceilos456 in forum Software PlayingReplies: 1Last Post: 22nd Aug 2007, 19:23
