If i try to uninstall i get this...
[img]file:///C:/Documents%20and%20Settings/Owner/Desktop/kazaa/norton.JPG[/img]
I have no idea whats it talking about. I am the only one using this computer. I have admin rights but i dont know what to do. It says go log in but i cant find anywhere you have to log in.
Any idea?
Originally Posted by AND1
Normally, you should have two user names in the computer, first yourself and the other Administrator. You can login as Administrator and make yourself as Administrator. You have to go in the Control Panel for users. Go in: Start> Control Panel> users and passwords.
You have to adjust the settings in the taskbar area to display the logoff and the logon. Go to start>settings>taskbar and start menu> click advanced>tick "display logoff".
If you want to uninstall Norton's Internet Security, you have to in Control Panel to remove the program. To do this: Start> settings> control panel> double click add/remove programs. -
the add/remove programs doesnt work. I found out how to take it off. If anyone has a problem with it -- go to norton website and download a file called RNIS and this should take it off completely.
Question about Norton Internet Security
By sohaibrazzaq in forum ComputerReplies: 3Last Post: 9th Oct 2010, 10:51 -
An internet security suite or individual applications?
By Rudyard in forum ComputerReplies: 1Last Post: 3rd Mar 2009, 07:33 -
Norton Internet Security 2009 deleted StaxRip
By lacywest in forum ComputerReplies: 2Last Post: 17th Feb 2009, 23:03 -
Free Comodo Internet Security Suite.
By wtsinnc in forum ComputerReplies: 4Last Post: 26th Sep 2008, 02:25 -
Kaspersky Internet Security 7.0 installation Conflicting with Internet Exp
By Krelmaneck in forum ComputerReplies: 2Last Post: 5th Oct 2007, 03:36
