  1. I'm thinkin about picking up this card...
    WinTV-PVR
    specs are listed here
    Product Description - Hauppauge WinTV PVR - TV / video / radio input adapter - PCI
    Device Type - TV / video / radio input adapter
    Enclosure Type - Plug-in card
    Interface Type - PCI
    Video Input - TV tuner - plug-in card
    Analog Video Format - PAL
    Analog Video Signal - S-Video, composite video, HF TV signal
    Digital Video Format - MPEG-1, MPEG-2, AVI
    Digital Video Capture Speed - 25 frames per second
    Digital Video Capture Resolution - 704 x 576, 384 x 288
    Audio Input Support - Included
    Sound Input Mode - Stereo
    Tuner Frequency Range - 87.6 - 108 MHz
    Min Operating System - Microsoft Windows 95/98, Microsoft Windows 2000 / NT4.0
    I've bolded the Analog Video Format... My question is PAL isnt that Europe standards and isnt US NTSC??? Does this mean I wont be able to use this card in the US???
  2. Chris S ChrisX's Avatar
    Jan 2002
    Some dude from Sydney
    Yes, you are right with this WinTV-PVR is for Europe and the UK. This isn't for USA and Japan.
    You have to get a multi-system TV or video card to view and capture PAL as well as NTSC.
    You should look for information on the types of capture cards you can buy on the left side of this web page. Make sure you get what you want and don't get caught of getting a card with macrovision built in.
    My new video card is: Leadtek's Winfast A250 TD, "My Vivo Edition" and this one is an excellent capture and graphics card. They recently won an award for the best video card in the market. The captured video is awesome. WOW! NTSC and PAL viewing and capturing. VIDEO FILES POSSIBLE: MPEG 1, MPEG2, VCD right up to DVD quality capturing.
    If you want to use this video card to capture DVD's from the DVD player, this one will be a problem for you. This video card has a macrovision sensor built in, so no capturing is possible from the external DVD player. A macrovision hack might help you?
    I also have another capturing device, Win2000 TV card in another computer. This one is PAL and NTSC compatible, just like the one above and fortunately no macrovsion will stop me recordng from the DVD. The resolution isn't as good however.
    The program Win2000 is the updated downloaded version due to incompatiblity with the later OS Windows 2000.
    Anyway, I am looking into DVD ripping very shortly. I got all downloads ready to process in my computer and having the time is the only problem. This is the only way to get around the stupid macrovision on my own DVD into my own computer. I have a right to back up my own videos in the HD at home. Blasted the movie industry.
  3. Member SHS's Avatar
    Oct 2000
    Vinita, Oklahoma
    Tomoyo Narusegawa check out the new PVR 250 and when come to the Tuner if you get a PAL Tuner it will not work in with NTSC broadcast nor the other way a round but what you do is use the S-Video/Composite input that works any where in the world.
