Hi,
I have Xingmpeg,Tmpge and Nero. I follow the methods to make a perfect VCD converting pal files 2 ntsc mpeg files and then burnin it. But after that, when i put my vcd on dvd player(ntsc only) i watch it with the botton cut off(40 to 50 lines cut). The question is : Is there a way to stay with this 40 or 50 lines of the botton ? I've been searching on the web for this, and i found on some sites that this is normal, and nothing about that was discussed here. Maybe there's an answer to that. Thanx
Results 1 to 1 of 1
pc crashes when using tmpge 4.0
By ANTS17 in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 22:55 -
.avs scripts in TMPGE Xpress?
By ecc in forum Video ConversionReplies: 0Last Post: 12th Aug 2008, 07:39 -
TMPGe and BD template the right settings for pal -getting juttering effect
By millzy in forum Authoring (Blu-ray)Replies: 0Last Post: 31st Jul 2008, 10:13
