Hi!
I was just wondering what the difference is between DVDSplit 0.4 and DVDSplit 0.5.
Bye!
[-KvejkarN-]
you buy it
http://ifoedit.wh.fr0zen.com/dvdsplit.html -
But can you copy extras with the 0.4?
At his homepage it says that 0.5 will copy the extras automaticaly, if chosen. I used 0.4 once but I never came across any options about copying extras automaticaly.
If the only differences are as you specified, then you should be able to copy extras. How is it? If you can do this in 0.4, how do you do it then?
Bye! //
[-KvejkarN-]
is it possible to feel the difference?
By FaisalKhan in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jan 2011, 05:17 -
Difference matte?
By Abiyad in forum MacReplies: 3Last Post: 22nd May 2008, 15:38 -
What's the difference between these two products?
By Waterkips in forum Capturing and VCRReplies: 1Last Post: 21st Apr 2008, 00:40 -
What is the difference between these conversions?
By neo_74 in forum AudioReplies: 2Last Post: 3rd Jan 2008, 19:42 -
Can YOU Tell the Difference ?
By Seeker47 in forum DVB / IPTVReplies: 14Last Post: 19th Nov 2007, 12:59
