I'm losing a ton of frames... I've set my computer to "optimal performance" by following the guidelines at http://scmmicro.custhelp.com/cgi-bin/scmmicro.cfg/php/enduser/std_adp.php?p_refno=011004-000020
Still no good... please help!
check the source and the frame rate setting ie Pal source then mark 25 fps
if NTSC the 30 fps....stick to that and all should be good also check out the how to guide's which have been a valuable source of info....I am not sure if you are new to all this video capping business so maybe you already know all this.....I hope Ive helped
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 21:15 -
mencoder: seeking to frames (or cropping start frames)
By manchurian_candidate in forum LinuxReplies: 3Last Post: 13th Dec 2010, 08:53 -
HDTV to DVD using DGIndex/AviSynth losing frames
By gadgetguy in forum Video ConversionReplies: 13Last Post: 3rd Sep 2008, 16:12 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 20:59
