Does anyone have a good way of calculating/estimating what bitrate to use when encoding using TMPGEnc given a certain sized vob file?
i.e.
VOB file starts out 5.8GB -> Encode using TMPGEnc Bitrate=4000 -> 4.1GB m2 -> Burns to DVD-R successfully (.ac3 file=.3GB)
While trying to use the highest bitrate possible. I have it down to a process of estimating to within +/-500 kbits/s, but would really like to fine tune it to +/-100kbits/s. To optimize the final DVD-R quality.
I've tried all the bitrate calculaters but found in the TOOLS section but find they are all geared toward SVCD's and don't seem to give me very accurate info. Is there a TMPGenc bitrate calculator that works the way I describe maybe? Anyone have a tabulated spreadsheet?
Any advice or suggestions would be hugely appreciated.
rhuala
Bump... someone must have a good system for encoding using TMPGEnc to opimize DVD-R quality?
rhuala -
Use the java bitrate calculator in the tools section. It supports DVD and I find it to be accurate enough. Remember to allow space for menus and stuff if you use em.
The version I have of TMPG allows you to play around with the bitrate and graphically shows the amount of DVD-R space used.
TMPGEnc "clip total bitrate too high for a DVD-Video" issue
By dread in forum Authoring (DVD)Replies: 7Last Post: 26th Oct 2010, 16:34 -
TMPGEnc says "clip total bitrate is too high for a DVD-Video" but it's not?
By sasuweh in forum Authoring (DVD)Replies: 24Last Post: 30th Sep 2010, 04:17 -
How to get pixel values of MB in x.264
By polovn in forum Newbie / General discussionsReplies: 0Last Post: 2nd Mar 2009, 04:19 -
TMPGEnc DVD Author Error - Video Bitrate too high
By powerkoala in forum Authoring (DVD)Replies: 9Last Post: 22nd Nov 2008, 12:16 -
DVD Shrink and TMPGENC bitrate problem
By haddockd414 in forum DVD RippingReplies: 2Last Post: 12th Mar 2008, 13:31
