Want to capture Avi virtualdub wont work,
it says i have not capture card, i have been using
powervcr but it will only capture in mpeg format,
can some suggest a programme which will capture Avi?
I'm assuming you have progressed beyond Win98? If so, try iuVCR or VirtualVCR.
Virtualdub avi capture audio sync issues
By buckethead in forum Capturing and VCRReplies: 8Last Post: 31st Oct 2011, 15:34 -
DV capture from sony HDR-HC9E to AVI thru virtualdub
By one1 in forum Capturing and VCRReplies: 10Last Post: 28th Jul 2010, 21:50 -
which prog to capture ?
By hydra3333 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 04:19 -
Which prog to get audio to work on DVD?
By bytheway in forum Newbie / General discussionsReplies: 2Last Post: 3rd Apr 2008, 20:40 -
suggestion for vhs capture card
By abbymat in forum Capturing and VCRReplies: 8Last Post: 28th Jul 2007, 01:57
