Hi
I am searching an easy guide to convert my AVI files to SVCD. I want to watch the SVCDs on a Pioneer DVD player. The AVI files were obtained by Ulead Movie Factory from a Panasonic DV camera NV-EX1 via FireWire.
I saw some guides converting Divx files to SVCD using CCE but I am not sure if this is the right way.
Anyone knows a good link or has their own experience?
thanks
mipo
We need more information to help. Do you want to burn your SVCD files to CDR or DVDR? Are you looking for maximum quality or trying to fit as much film as possible in one disk?
Anyway, you will need CCE or TMPGenc to encode your avi´s to mpg2. -
well, i like to have a guide showing me how to make a SVCD from the a film in the DV-cam from scratch including best capture methods and best quality in relation to a sensible size!
so from DV-CAM 2 PC, from PC 2 SVCD well the encoding process u could skip because there are other guides here about that but actually preparing the DV-film for svcd encoding is the thing i am totally unaware about!
do u need more information?
greetz
tommybskazaa rules... -
Assuming you want to burn to CD´s and get maximum quality, just select with TMPGenc the SVCD template (Pal or NTSC), load your avi file and encode. Final result will be an mpg2 file that you can burn to CD with Nero or similar software. This will give you around 35 minutes of film in one standard disk.
well thats not wot i was asking for b/c that s easy to encode. i wanted to know how to prepare the DV-avi or even actually how to capture it with what quality so later i can encode it to svcd?
kazaa rules... -
DV Video tends to be clean as far as noise is concerned. There isn't much you need to do to it to encode. It's interlaced, bottom field first. Leave it that way. If your AVI is Type-1, and depending on how old your version of CCE is, you may need to convert it to Type-2 DV. There are freeware converters in the TOOLS section.
Other than suggesting Multipass VBR, and possibly using CVD resolutions to maximize your bitrate, there isn't much 'prep' work to be done. Since your using CCE, ensure you use the Alternate block scanning order (for interlaced video). Search the forum for 'cam' and 'matrix'. Someone posted a Cam specific matrix that's supposed to perform well.Impossible to see the future is. The Dark Side clouds everything...
Tutorials: The Complete Guide to Macintosh Video Conversion
By galactica in forum MacReplies: 40Last Post: 9th Jan 2019, 18:25 -
Simple MKV to MP4 Conversion Guide (Xbox360)
By Cloud101 in forum User guidesReplies: 35Last Post: 8th Nov 2011, 16:41 -
Searching for software used in conversion
By Mildragon in forum Video ConversionReplies: 0Last Post: 8th Oct 2011, 15:51 -
searching for a guide....
By videoman3344 in forum Video ConversionReplies: 2Last Post: 20th Oct 2009, 03:13 -
CCE guide for PAL to NTSC conversion
By alexs_eu in forum Video ConversionReplies: 9Last Post: 21st Jun 2008, 07:41
