Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. I made a movie for school, and shoved it on a VCD, its plays on my DVD player, i hooked up my dvd player to my vcr, it didint work, just static. Then i went through the TV to the vcr, so it worked dvd>TV>vcr, didint work, now im wondering if there is a way to do this, or if the combo dvd/vhs players do this. Thanks - Jampack
  2. Hi
    2 things to try
    1st you have to select AUX or similar as the input on your VCR.
    2nd make sure you have the DVD video out set to composite, most VCR's will not take an RGB input.
    Hope it helps
